Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-24T15:23:28+00:00
    Great solution, thanks a lot mate!
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T15:40:28+00:00
    So you select Shutdown from the Power menu and do not experience a drop overnight? I'd be interested in what happens if you charge to 100% and then shutdown for the night as to what the battery % reads in the morning when you turn it on again.
    At the risk of repeating myself...
    If you need to use your surface laptop for something work critical & on battery only, try my solution. Since there were no references to it at all, in this race for a new firmware, I imagine that noone else has tried it..
    I had to sit through multiple presentations from 9am til 5pm and my battery life was at 65% by the end with mixed use. (powerpoints, word docs, online articles etc)
    My solution was to switch off hibernation**:**
    command prompt, **type****powercfg.exe /**hibernate off
    I can now shutdown and switch on like before and it works like when I first got it.
    Good battery life and the percentage stays the same overnight unplugged.
    Obviously it breaks hibernation, but hopefully when a new firmware is released to fix the battery bug, you can reactivate hibernation by going
    command prompt, **type****powercfg.exe /**hibernate on
    2019-09-24T16:12:21+00:00
    To be fair, I can't say that my SL2 battery life has been bad. Even with 75%, I get several hours out of it.
    2019-09-24T16:35:53+00:00
    I've tested it with both shutdown and sleep.
    After the 1909 update didn't resolve anything 3/4 days ago, I decided to rollback to 1803 and just disable hibernation.
    (From there I did some testing as I needed to use the laptop on the road the coming week.)
    When I shutdown from the power menu, I unplugged the power and after switching back on after 30 minutes, it was still at 100%.
    I then tested it overnight, and I got the same result, 100% at night and 100% in the morning too (obviously, from then on I'd leave it charging overnight - because most people leave the charger plugged in at home I'd imagine).
    Sleep mode (via the power button on the keyboard) works pretty well too, with maybe 1 or 2% drain throughout the day.  I was very impressed with the battery life when I got it, and I'm just glad that there is a workaround until Microsoft release a proper firmware fix that will sort all this out.
