Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-24T11:47:24+00:00
    Also note that I am suspicious of the "Driver Date"!  This problem seems to be effecting Surface models across the board and not just the new ones.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T11:52:24+00:00
    Driver dates aside, which I know to be bogus, https://support.microsoft.com/en-us/help/4037237/surface-surface-laptop-update-history shows that as the current firmware.
    2019-09-24T11:59:18+00:00
    Now, that firmware could have been installed a few builds ago since those are "one time shots" for installation.  Unknown if it actually was with the build.  Normally, you do get a KB list of the updates but this system has received none since the latest build came across.
    For those that did not get the firmware update, it should have came across automatically for those systems that did not have it.  Windows Update is "supposed" to check model numbers and build numbers of the machine and system when it scans the database.  If people have to force feed the update, there may be an issue with Windows Update as well.
    Who knows!  I don't consider it a problem on my own since the machine stays at home all the time.
    2019-09-24T13:53:54+00:00
    At the risk of repeating myself...
    If you need to use your surface laptop for something work critical & on battery only, try my solution. Since there were no references to it at all, in this race for a new firmware, I imagine that noone else has tried it..
    I had to sit through multiple presentations from 9am til 5pm and my battery life was at 65% by the end with mixed use. (powerpoints, word docs, online articles etc)
    My solution was to switch off hibernation**:**
    command prompt, **type****powercfg.exe /**hibernate off
    I can now shutdown and switch on like before and it works like when I first got it.
    Good battery life and the percentage stays the same overnight unplugged.
    Obviously it breaks hibernation, but hopefully when a new firmware is released to fix the battery bug, you can reactivate hibernation by going
    command prompt, **type****powercfg.exe /**hibernate on
