Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-24T11:34:31+00:00
    I looked at the update history and no "KB" numbers are listed.  In fact, it only mentions the Preview Builds by number only.  In fact, only the Drivers and Windows Defender displays any kind of list.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T11:39:06+00:00
    Can you check device manager for the firmware version for your Surface Laptop 2 for this firmware? The version shown below is the last public release documented at https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history - what version does your SL2 show?
    Surface System Aggregator - Firmware
    • 145.210.139.0 improves battery performance.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T11:44:11+00:00
    Firmware should show under Driver Updates.
    2019-09-24T11:44:49+00:00
    I actually have the 1st generation model Laptop and here is what the panel says:
