Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-24T00:20:20+00:00
    Do you guys have a new firmware update after enrolling to release preview on Surface Laptop 2?
    Just got my replacement and depsite the fact that I've paused the updates it updated to the problematic firmware once again.
    EDIT: there isn't any firmware update on release preview ring.
    2019-09-24T03:13:01+00:00
    The firmware comes built into the build.  You will not see it on the update list.
    2019-09-24T06:28:05+00:00
    Looks like the fix "did" work for a short time and is back doing it again and am on the machine with Build 18985.  I am noticing sub-letters to the build numbers lately and got two builds in the same number of days.  I think that they are working on it and since my Laptop is only used for testing and general use, I do not use it as a daily driver.
    For firmware - in the past, I have looked up "KB" numbers and usually get TechRepublic as the source with the answers.
    With a power drop like what these are getting, you just cannot rely on these machines in a mobile fashion unless you have an A/C outlet nearby and take the charger with you.  Really a shame.  My Pro 3 has the RTM release on it and generally don't use it much either.
    Been spending a LOT of time on my iMac and my MacBook Pro!  These Surface machines are becoming decorations.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-24T10:01:02+00:00
    I do not think that firmware is distributed with builds and not documented. I
    have asked for clarification.
    https://twitter.com/barbbowman/status/1176435790445993984?s=20
