Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-23T14:50:45+00:00
    I experienced no power loss this morning after an overnight shutdown, but I did experience the 25% drop after shutting down for a few hours last night.
    So the bottom line is that it seems to be inconsistent.
    2019-09-23T14:53:48+00:00
    I just subscribed for the Insider Program... (The Slow Ring, more stable one)
    After a few minutes and a few clicks in the CHECK FOR UPDATES, it downloaded and installed one FIRMWARE for my SP6.
    I did one small test of charge to 100%, shutdown, disconnect, and wait for 30 minutes and turn on again..... STILL 100%!!!
    Looks like it worked!!!
    2019-09-23T14:59:53+00:00
    This is one topic that is growing to the point of being the largest.  Under the "Power and Battery" category of the Hub, you can tell that it is largely ignored by Microsoft.  They do know about the issue and it also turns out that the battery drain issue doesn't always happen as well.  I disconnected the Laptop for 24 hours then hooked it up again and no loss in power.
    There has to be something running while the machine is off.
    Here is the link to my recent post :
    https://aka.ms/AA64dtk
    2019-09-23T15:22:13+00:00
    I don't think that anything is running. There's no indication of that in any of the diagnostics.  Also, when it does happen, the power loss is about the name (25%) no matter how long the device is shut down for. Literally no process should be able to drain 25% of the battery when the device has only been shut off for 5 minutes, and also not drain any more than that when it's off for 8 hours. The firmware has to be misreading the charge. Either the battery isn't actually at 75%, or it never charged past 75% in the first place.
