Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-22T15:31:18+00:00
    I rejoined the release preview, restarted a few times, no further updates appear to be available.
    2019-09-22T15:38:21+00:00
    Just to be sure, I did the same, but no extra firmware updates for me (Laptopo 2).
    I have only this
    And I still confirm the battery issue is gone and the dawning is good and steady, so for me the issue is fixed
    2019-09-22T15:38:46+00:00
    I don't imagine there will be.
    Unless some users can confirm that the firmware is for the surface laptop 2 (or 1st gen).
    The fix is only for the surface Pro 6. Firmware isn't universally compatible across the entire lineup as they all have different specs.
    If upgrading to 1903 or 1909 fixes your battery issues then that's good, but as of right now I don't believe MS has released a firmware for the surface laptops yet.
    2019-09-22T15:48:03+00:00
    I thought it was fixed for me too... until this morning. I hope that it is truly resolved for you.
