Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-08-18T20:13:06+00:00
    I agree. Something like this should not even be an issue, especially if you pay over $2K for the unit.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-08-19T10:37:00+00:00
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-08-19T10:38:44+00:00
    It probably would be worth it to try recalibrating. Run on battery until it
    shuts down on its own for no power and charge fully. Repeat 3x. That "should"
    recalibrate. I've been reporting these threads with this issue to an internal
    contact but get no replies.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-08-20T09:56:18+00:00
    My internal contact replied to my email with "Customers should call into support and also file feedback hub item and share the link to it. " File a Feedback Hub problem report, get the shared link and post it here in a reply.
