Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-16T10:24:56+00:00
    I made a new observation last night into this morning.
    Last night, I shut down my PC as usual, but rather than unplug it I left it plugged in for about 30 minutes before putting it away for the night. When I started it up this morning it was 99% charged.
    This further confirms that the apparent 25% power loss is not something that occurs gradually while the device is off but rather occurs immediately upon shutdown.
    I don't see how the battery could actually lose 25% of its power in an instant upon shutdown, but I also don't understand how if it's just the firmware misreading the charge every indication is that it's accurate, as charging appears to occur when it's connected to power, it will die sooner if not charged back to 100%, and as far as I can tell this loss and gain of about 25% each day is counting towards my battery cycles, thereby shortening the lifespan of the battery.
    2019-09-16T19:25:32+00:00
    Be sure to report on the Feedback Hub.
    Please upvote other reports such as mine to ensure that MS takes this issue seriously: https://aka.ms/AA5w24b
    This link quoted says my account does not have access.  Are you on an Insider builds perhaps?
    This one worked for me:
    https://aka.ms/AA631t2
    2019-09-19T02:18:29+00:00
    Funny enough, the link you posted says that I don't have  access. I can't explaining it. I just pasted the link provided when I share the report. I'm definitely not using any special build.
    In any case, I'm still waiting on a fix. I see new reports of the same issue every day on the Feedback Hub.
    2019-09-19T07:37:21+00:00
    Andrew,
    There's a Windows Insider build that got pushed out today that has appeared to have fixed all battery issues.
    If you want to try out your mileage, type "Windows Insider" into the search bar and follow prompts. Select the option that allows you to get future updates immediately.
    Windows version should be 1909 and you will see some Surface firmware in the queue which contains the fix
