Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-15T07:15:05+00:00
    I've got the impression, too, that the battery life is way too short. Just a few hours. I have no comparison because I bought it innthe beginning of August when the "74/75% battery problem" was already there.
    2019-09-15T14:12:03+00:00
    I have the Same Surface Pro 6. Exactly the same issue.
    2019-09-15T15:18:49+00:00
    Be sure to report on the Feedback Hub.
    Please upvote other reports such as mine to ensure that MS takes this issue seriously: https://aka.ms/AA5w24b
    2019-09-15T19:21:52+00:00
    I am having the same problem.  Just wanted to comment on this thread so I can stay up to date with the latest information and (hopefully) find out when there's finally a fix.
