Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-08-18T19:26:30+00:00
    I know about fast start. I mentioned above, I shut it off and I still lost about 9% overnight.
    And apparently, with fast start still off, I lost over 20% today while my PC was off for less than 20 minutes! I don't see how that's possible given that my battery lasts for 10+ hours when the computer is in use!
    2019-08-18T19:38:08+00:00
    My previous Surface Pro 6 that I took in for replacement due to the battery issues I was able to observe a 25% loss when the device was shut down and within a 20 minute span!
    With my latest replacement unit here is what I have found out so far, and I hope this is a solution.
    I charged my Surface unit to 100%, then used it unplugged until the battery depleted and died on me, then I charged it all the way back up to 100%.
    It is too early to tell if that solved the issue but so far I am not seeing any drop when I turn on my device. I will update after a week, and a month after.
    2019-08-18T19:50:48+00:00
    This would also seem to suggest that it's not actually a battery drain issue but rather poor calibration of the software reading the charge.  That's a less troubling problem, at least, but still very annoying and disappointing for MS's flagship devices. Regardless of what's going on I would very much like a fix.
    2019-08-18T20:12:18+00:00
    My Android Phone (LG V20) and my Lenovo Thinkpad P50 both have battery calibration software to help extend battery life, and I can buy and install new replacable batteries for both of them without having to perform major screen surgery to it. I have my P50 set to stop charging at 85% to slow down battery degradation and it works just fine.
    Surface products could use a similar battery utility.
