Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-09T16:36:09+00:00
    Hey Everyone,
    I posted a possible "fix" on the Surface sub reddit and a couple people have reached out to me and told me it has cured their battery issues...
    Didn't work for me.
    I followed these instructions to the letter, I left my Surface Pro 6 with a 100% charge last night and woke up this morning to 69% remaining...
    2019-09-10T05:02:42+00:00
    It seems I had Updates turned on again and my Surface updated Firmware (and Windows?). Got the same problem again now, too.
    2019-09-10T05:09:55+00:00
    This thread is REALLY long. Has anyone tried anything that worked? If so, what were the steps? I would like to try a few potential fixes!
    2019-09-10T05:18:43+00:00
    I dont believe there has been a solution that has worked permanently for everyone.
    Best bet at this point is to make nosie at Microsoft. Create feedback in the app and search for and upvote other people's battery feedback.
