Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-05T13:26:45+00:00
    I received my replacement device (2nd one now) from Microsoft today and am wondering if I should be cautious with the updates. All those who are facing this battery drain issue, have you updated to the Feature update to Windows 10, version 1903?
    2019-09-05T13:40:57+00:00
    I replied to you in the other thread as well, but for the benefit of others who might be wondering, I experienced this issue both before and after updating to version 1903, so it doesn’t seem to be a factor.
    2019-09-05T13:46:49+00:00
    I received replacement, too. 1803 and disabled all updates just to make sure. The error is gone. Had shut it down twice for about 8 hours and still 100% battery. It has to be either firmware update or Windows update. Battery log looks good.
    2019-09-06T11:23:00+00:00
    Another day, another start up at 74%.  Still waiting on that fix from Microsoft.
    I hope this isn't counting towards battery cycles and shortening the overall life of my battery.
