Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-03T11:58:47+00:00
    Uninstalled SKYPE = no more battery drain (Surface Pro 6)
    Can someone confirm this?
    2019-09-03T15:51:47+00:00
    I can confirm that when I got my new Surface Pro 6 the first thing I did when starting it up was uninstall all the programs and apps I don't ever use like Skype and a few others.
    Today it is 9/3 and my battery is still having the same issue.
    I also tried that troubleshooting step recommended by someone where a series of steps are taken to include leaving the unit off for 10 to 12 hours then using it to completely drain it. At first that seemed to resolve the issue, then I got some new microsoft updates which I accepted and installed.
    I don't know if those updates reversed those troubleshooting steps I took that seemed to help earlier but all I can say is my brand new Surface Pro 6 is back to square one.
    I woke up this morning around 4am to use the restroom, decided to unplug the charger from the unit that has been left charging overnight, went back to bed. I woke up again close to 9am, turned on the unit and this is what I saw:
    2019-09-03 <br>04:18:00 Suspended 102 % 49,060 mWh
    08:43:48 Active Battery 75 % 36,710 mWh
    08:44:15 Report generated Battery 75 % 36,710 mWh
    2019-09-03T16:04:25+00:00
    Just wait for the MS patch :)
    2019-09-03T20:46:12+00:00
    At this point it doesn't seen that anything is going to resolve this problem except an update send out by MS.
    So seriously, everyone having this issue, keep bugging them! I know they said they're working on it or whatever, but that can mean a lot of things, and for a massive company like MS with massive products like Windows and the Surface line of devices, they have issues that are priorities and ones that aren't. This should be a priority. One of the reasons why I paid a premium price and purchased a Surface device is because I figured that something made by Microsoft themselves was sure to give me the best, bug free, Windows experience, and certainly the best support if any issues did occur. This issue is something that I've never even experienced on $200 budget netbooks! How it dealt with from this point is pretty much going to determine if I buy Surface products in the future, and whether I recommend them to friends.
