Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-02T17:48:48+00:00
    Same problem on my Surface Pro 6.
    2019-09-02T17:55:41+00:00
    Firmware of the battery? As far as I know the battery is just a collection of electrochemical cells. I think they must have meant the OS firmware that interacts with the battery, like the drivers and such.
    2019-09-03T06:35:41+00:00
    Uninstalled SKYPE = no more battery drain (Surface Pro 6)
    2019-09-03T10:04:45+00:00
    After a few shutdowns without issue it happened again this morning. Started up with 84% : (
    At least that's better than 75%...
