Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-08-24T05:33:30+00:00
    Why does it need to remain off for 10-12 hours? That part seems weird. Other than that, it just sounds like a combination of reinstalling battery drivers and recalibrating. I’ve tried both separately but not in conjunction.
    2019-08-24T06:01:57+00:00
    I'm glad I found this thread. Mine started showing these issues about 2-3 weeks ago. The worst I've had was a 60% drop in 4 hours when in sleep. It's sad as this unit is less than a month old :(
    2019-08-25T05:36:46+00:00
    2019-08-25T21:05:47+00:00
    Has anyone here been able to verify that this "fix" works? I haven't had an opportunity lately where it's been convenient to shutdown my PC for 10-12 hours, and frankly, I'd like some confirmation that this works before I even bother to try.
