Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
  1. Deleted
    2019-08-17T15:44:24+00:00
    Note the overnight drops on 2019-08-16 from 100% to 72% and 2019-08-17 from 98% to 73%.
    Recent usage
    Power states over the last 3 days
    2019-08-1411:41:00 Active Battery 52 % 25,530 mWh
    11:42:02 Connected standby Battery 52 % 25,060 mWh
    12:54:33 Connected standby AC 51 % 24,880 mWh
    12:54:34 Active AC 51 % 24,880 mWh
    14:19:51 Connected standby AC 99 % 48,150 mWh
    14:22:03 Active AC 99 % 48,150 mWh
    16:19:24 Active Battery 100 % 48,400 mWh
    16:21:53 Connected standby Battery 100 % 48,400 mWh
    21:06:00 Connected standby AC 100 % 48,400 mWh
    21:06:02 Active AC 100 % 48,400 mWh
    23:20:25 Connected standby AC 100 % 48,400 mWh
    2019-08-1500:48:35 Active AC 100 % 48,400 mWh
    00:49:47 Connected standby AC 100 % 48,400 mWh
    00:49:47 Suspended 100 % 48,400 mWh
    09:15:01 Active AC 74 % 35,810 mWh
    10:03:14 Active Battery 95 % 46,360 mWh
    10:03:18 Active AC 97 % 47,020 mWh
    10:09:10 Active Battery 97 % 47,020 mWh
    10:09:19 Active AC 98 % 47,770 mWh
    10:44:29 Connected standby AC 98 % 47,720 mWh
    10:44:29 Suspended 98 % 47,720 mWh
    16:35:24 Active AC 98 % 47,620 mWh
    16:46:50 Connected standby AC 98 % 47,620 mWh
    16:47:22 Active AC 98 % 47,620 mWh
    16:57:26 Connected standby AC 98 % 47,620 mWh
    17:10:14 Active AC 98 % 47,620 mWh
    18:03:39 Connected standby AC 98 % 47,620 mWh
    18:06:35 Connected standby Battery 98 % 47,620 mWh
    18:06:40 Connected standby AC 98 % 47,620 mWh
    18:43:20 Connected standby Battery 98 % 47,620 mWh
    18:43:30 Connected standby AC 98 % 47,620 mWh
    18:56:23 Connected standby Battery 98 % 47,620 mWh
    18:56:28 Connected standby AC 98 % 47,620 mWh
    18:58:19 Active AC 98 % 47,620 mWh
    23:53:06 Active Battery 100 % 48,760 mWh
    23:53:53 Connected standby Battery 100 % 48,760 mWh
    23:57:03 Connected standby AC 100 % 48,760 mWh
    23:57:03 Active AC 100 % 48,760 mWh
    2019-08-1601:12:24 Connected standby AC 100 % 48,760 mWh
    01:14:30 Active AC 100 % 48,760 mWh
    01:15:06 Active Battery 100 % 48,760 mWh
    01:16:57 Connected standby Battery 100 % 48,760 mWh
    02:17:19 Active Battery 100 % 48,760 mWh
    02:17:41 Connected standby Battery 100 % 48,760 mWh
    02:17:41 Suspended 100 % 48,760 mWh
    09:36:52 Active AC 72 % 35,210 mWh
    13:13:53 Connected standby AC 100 % 48,680 mWh
    13:19:51 Active AC 100 % 48,680 mWh
    13:20:07 Connected standby AC 100 % 48,680 mWh
    13:24:58 Connected standby Battery 100 % 48,680 mWh
    14:35:52 Connected standby AC 100 % 48,680 mWh
    14:35:54 Active AC 100 % 48,680 mWh
    15:52:33 Connected standby AC 100 % 48,680 mWh
    18:56:14 Active AC 100 % 48,680 mWh
    20:24:49 Active Battery 98 % 47,860 mWh
    20:29:58 Connected standby Battery 98 % 47,860 mWh
    20:31:32 Active Battery 98 % 47,860 mWh
    20:32:04 Connected standby Battery 98 % 47,860 mWh
    20:32:06 Active Battery 98 % 47,860 mWh
    20:32:26 Connected standby Battery 98 % 47,860 mWh
    20:32:29 Active Battery 98 % 47,860 mWh
    20:32:37 Connected standby Battery 98 % 47,860 mWh
    20:32:56 Connected standby AC 98 % 47,860 mWh
    20:36:02 Active AC 98 % 47,860 mWh
    21:40:38 Connected standby AC 98 % 47,860 mWh
    2019-08-1700:07:53 Active AC 98 % 47,860 mWh
    00:39:11 Connected standby AC 98 % 47,860 mWh
    01:26:13 Active AC 98 % 47,860 mWh
    01:43:15 Connected standby AC 98 % 47,880 mWh
    01:43:15 Suspended 98 % 47,880 mWh
    10:07:21 Active AC 73 % 35,630 mWh
    11:00:00 Suspended 96 % 46,780 mWh
    11:01:05 Active AC 99 % 46,780 mWh
    11:07:33 Report generated AC 99 % 46,780 mWh
    2019-08-17T15:43:22+00:00
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Laptop 2
    BIOS 137.2706.768 04/18/2019
    OS BUILD 17763.1.amd64fre.rs5_release.180914-1434
    PLATFORM ROLE Mobile
    CONNECTED STANDBY Supported
    REPORT TIME 2019-08-1711:07:33
