Pen pressure and tapering problems
2015-11-08T20:03:41+00:00
I love the new SP4 pen, but I've noticed the pen pressure is not consistent. The biggest problem is that paint brush strokes in Photoshop don't taper smoothly when drawing. I tired using the SP4 pen on my Surface Pro 3 and it doesn't have any problem. Here is a screen capture of what I'm talking about.
Since the pen isn't the problem I'm assuming it's a calibration issue with the Surface Pro 4. I downloaded new Wintab drivers to see if that would solve the problem (got the idea from this thread about pen problems).
It's not just Photoshop. The actual Surface pen pressure app has the same problem. It's harder to see because the brush strokes are thinner, but there is a much faster tapering happening than there is on the Surface Pro 3. Here is a screen cap:
2016-07-15T19:53:13+00:00
Hey Everyone!
Thanks for all the feedback!
As some of you have already noticed, on July 14th, 2016, we released an update to the Surface Touch Driver that should significantly improve the pen tapering and pressure experience that this thread talks about.
For more information on the 7/14 update, you can go here.
If you experience any difficulty downloading or installing updates, please check the Troubles installing Surface and Windows updates article for assistance.
Thanks!
Zachary
156 additional answers
    2016-05-28T10:51:40+00:00
    Me too
    2016-06-17T00:19:00+00:00
    i have a surface pro 3 and have the same problem.
    did i set up something wrong?
    edit: i download a different version of paint tool sai (v2.0) and it works fine.
    tried photoshop cc and it works great also, seems like just some older software compatibility issue.
    2016-06-24T17:09:29+00:00
    It have been nearly a year since the sp4 came out and we still haven't a fix ?
    how shamefull microsoft
    Anyway i'm disapointed of you as always...
    2016-06-25T01:15:55+00:00
    I really think its just the settings panel.. the new windows ink sketchpad doesn't have the issue, and other apps like manga studio don't have it either.
