Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2020-03-05T15:00:17+00:00
    Same issue here too. 15' laptop 3 AMD 16G/512G.
    The computer will reboot randomly when using the stock charger. This never happen when using the battery.
    2020-03-10T16:23:09+00:00
    I am having this problem right now. 15' Laptop 3, AMD Ryzen 5, 8GB RAM. Started the day after I took it out of the box, has persisted 4 months now. Driving me nuts recovering all these files I lose. Desperately seeking a solution.
    2020-03-10T17:02:31+00:00
    I returned the laptop. Microsoft doesn't seem to be taking this to seriously. This is a broken product as far as I'm concerned.
    2020-03-10T20:10:52+00:00
    I completely agree it is a broken product.  It has reset 3 times in the last 30 minutes and is unusable.  I was going to take it back but decided to wait 30 days for a fix. Since there is no fix I am returning it tomorrow.  Did you have any problem returning it to the Microsoft store?
