Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2021-07-05T15:36:29+00:00
    If you’re still in your warranty period, set up a repair order, send it in, and they’ll fix/replace it.
    At least, that’s what I did, and my replacement device is great.
    No, it’s not a Windows issue, and reinstalling it isn’t going to fix it. It’s something to do with the processor, as far as I’ve been able to tell.
    Just let them know what you’ve done to resolve the issue so far when you CALL IN to talk to the tech and ultimately set up that repair/replacement ticket.
    2021-07-05T15:58:06+00:00
    Noted, if I get no luck with the restart I'll definitely send it in
    2021-07-23T16:07:21+00:00
    i have bought microsoft surface laptop 3 13.5" on march 2020. Recently, the laptop kept shutting down several times. I noticed these issue since last month (June 2021).
    Details:
    Quad-cure 10th Gen Intel Core i5-1035G7 Processsor
    8GB LPDDR4x RAM
    256GB SSD
    i have done windows update (Latest is 23 July 2021) to fix the issue as recommended. However, the issue is still not resolved and the laptop keep shutting down. Please advice.
    Fara
    2021-07-23T17:18:48+00:00
    Details:
    8GB LPDDR4x RAM
    256GB SSD
    Fara
    Contact their technical support department to arrange for repair/replacement of your device.
