Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2020-12-12T02:29:31+00:00
    All,
    About a month or so ago, also got fed up with the constant reboots (that started right as soon as I got my new Surface) and opened a ticket with Microsoft.  Microsoft had me do a hard reset (as they always do) and my Surface went into a loop and wouldn't recover (it just kept giving an error and rebooting constantly until the battery drained).  I actually got my replacement Surface fairly quickly and have NO issues with the replacement so I HIGHLY recommend going ahead and opening a ticket to replace your computer.  Of course backup your data before doing any kind of reset is also HIGHLY recommended.
    Hope this helps!
    2020-12-30T21:31:22+00:00
    Updated: 9/1/2020
    Greg
    This doesn't fix the problem!!!!!
    2021-01-05T17:45:27+00:00
    Did this issue get resolved for you?  I just purchased a Surface Laptop 3 with the same specs and it reboots constantly.  Wondering if I should just return it or if you were able to get yours to work. Thanks!
    2021-01-05T17:52:08+00:00
    Return it and buy a business version with Intel processors/chipset as this works.  The AMD model is junk and rebooting has not been resolved.
