Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2020-10-04T00:44:09+00:00
    Thanks for letting us know.  Just out of curiosity, did you buy directly from Microsoft or somewhere else?  I'm just wondering if I have to go back to where I purchased it.
    2020-10-04T04:21:08+00:00
    I did buy directly at microsoft.com.
  3. Deleted
    2020-10-06T02:03:40+00:00
    I have  had this update and my computer only 2 weeks old - keeps restarting itself and also freezing.
    I cannot get onto technical support to fix this.
