Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2019-11-28T23:44:33+00:00
    Hi JasonSanterre,
    Thanks for your response on this. We totally understand you there, Jason. We are still into this. For sure this is an inconvenient in your part but,  Is it possible if we proceed on some Reset on your device as of the moment? In that way we can check if this is a Software concern only on your device. Please let me know if that helps.
    Regards,
    Edd
    2019-12-02T23:18:04+00:00
    I've exactly the same problem with Ryzen 5, 16GB RAM. Brand new laptop purchased yesterday, nothing installed apart from Google Chrome, reboots randomly. All updates are up to date in 'Windows Updates'.
    I've turned of AMD audio compressor ability to turn laptop off (fix from another thread) will see how it goes, but it was for sleep problem, so not sure if applies to this as well.
    2019-12-03T14:15:03+00:00
    Having the exact same issue. Purchased used/returned from Best Buy at, what I thought to be at the time, a great price.
    Within three hours of set-up and coding some data it restarted three times, always after returning to my work when the computer is asleep. Not happy at all about this software glitch, I do not run any third party software and a factory reset did nothing to address this issue. Will be returning promptly and looking for alternative options...
    2019-12-04T02:10:29+00:00
    Nathaniel I am having the exact same frustration. Computer restarts on sleep or when I close lid no matter how I tweak the settings. Also brand new. Still trying to find a solution.. Very very disappointed thusfar.
