Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2020-05-14T03:21:55+00:00
    I consulted with mifrosoft on the phone and as the issue couldnt be resolved i received an exchange, returned my brand new laptop and received another brand new one. This one has no problems and works perfectly!
    2020-05-14T03:23:29+00:00
    Mine was the same, no change of settings could fix it abd eventually i got an exchange. I received a brand new and this one has no problems at all.
    2020-05-26T04:28:58+00:00
    I've had random restarts and random shutdowns too, it even happened during my exams, nearly caused me an incomplete because of it. Have tried everything from turning off the AMD Audio Processor to running the Surface Diagnostic tools to no avail. Have done 2 factory resets still with the same problem. Below are my event logs from 1074, apparently the winlogon.exe is the one restarting my computer.
    Specifications:
    15", AMD Ryzen 5, 16 GB Ram
    I've spoken to another Microsoft Agent previously and have since been emailing him but there has been no reply.
    Log Name:      System
    Source:        User32
    Date:          26/05/2020 12:08:35
    Event ID:      1074
    Task Category: None
    Level:         Information
    Keywords:      Classic
    User:          SYSTEM
    Computer:      Surface
    Description:
    The process C:\WINDOWS\system32\winlogon.exe (Surface) has initiated the power off of computer SURFACE on behalf of user NT AUTHORITY\SYSTEM for the following reason: No title for this reason could be found
     Reason Code: 0x500ff
     Shut-down Type: power off
     Comment:
    Event Xml:
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
      <System>
        <Provider Name="User32" Guid="{b0aa8734-56f7-41cc-b2f4-de228e98b946}" EventSourceName="User32" />
        <EventID Qualifiers="32768">1074</EventID>
        <Version>0</Version>
        <Level>4</Level>
        <Task>0</Task>
        <Opcode>0</Opcode>
        <Keywords>0x8080000000000000</Keywords>
        <TimeCreated SystemTime="2020-05-26T04:08:35.181425100Z" />
        <EventRecordID>4637</EventRecordID>
        <Correlation />
        <Execution ProcessID="972" ThreadID="1740" />
        <Channel>System</Channel>
        <Computer>Surface</Computer>
        <Security UserID="S-1-5-18" />
      </System>
      <EventData>
        <Data Name="param1">C:\WINDOWS\system32\winlogon.exe (Surface)</Data>
        <Data Name="param2">Surface</Data>
        <Data Name="param3">No title for this reason could be found</Data>
        <Data Name="param4">0x500ff</Data>
        <Data Name="param5">power off</Data>
        <Data Name="param6">
        </Data>
        <Data Name="param7">NT AUTHORITY\SYSTEM</Data>
      </EventData>
    </Event>
    2020-05-27T17:03:23+00:00
    I am having the same problem with Surface 3, AMD Ryzen 5. It will just restart randomly while I am working, and with the power cord plugged in. I am thinking about returning this laptop, as I've only had it for 6 weeks.
