Surface Laptop 3 Restarting Randomly
2019-11-25T00:32:58+00:00
I have the power settings set to NOT restart when the power is plugged in and NOT to go into sleep mode.
Even with these settings the laptop restarts randomly. I'll be writing code and it restarts. Its random.
Surface Laptop 3 15"
AMD Ryzen 7 Microsoft Surface Edition 2.30 GHz
16.0 GB RAM
Surface | Surface Laptop | Power and battery
2020-08-23T13:54:18+00:00
Thank you for reporting the issue.
We published new improvements and fixes for Surface Laptop 3 that improve device stability. You can get updates now by checking Settings > Update & Security > Windows Update. We recommend that you install these updates to keep your Surface performing its best.
For more information, please view the Surface Laptop 3 update history page.
Updated: 9/1/2020
Greg
191 additional answers
    2019-11-25T17:47:12+00:00
    Hi JasonSanterre,
    Thanks for the patience on this matter. We do have some few questions to clarify this out.
    We would like to know if the random restart shows after you install these application that you mentioned. Specially the Microsoft SQL management
    Because if possible we can try to uninstall and re-install them and check if it does the same thing. Otherwise, we might proceed on doing a Reset or a Fresh Start on it.
    Looking forward on your response. Please keep us posted.
    Edd
    2019-11-25T05:12:55+00:00
    Blah, as i was typing my response to you it restarted. Grrr
    Everything is up to date.
    Windows 10
    Version 1909
    OS Build: 18363.476
    Once i took it out of the box i installed Visual Studio 2017 and then Microsoft SQL Server Management Studio 18
    Other than that just FileZilla.
    Jason
    2019-11-25T01:16:42+00:00
    Hi JasonSanterre,
    Thanks for reaching Microsoft Surface Community. We thank you for taking advantage on our new Surface Laptop 3. We're sorry to hear with regards on your concern. Definitely, this is not the experience that we want you to have. We do have some few questions to further isolate the issue.
    If this is a new device, kindly make sure that you have fully run the manual updates on it.
    If everything is updated, what is the current OS version and build of it?
    Have you installed any 3rd party applications recently?
    Is this happening on the first place after you set it up?
    Regards,
    Edd
