Surface Duo Screen Saver
2020-11-09T14:53:00+00:00
Has anyone tried or know if Duo has the capability of running a screensaver? I essentially use it as a laptop in meetings and rather than the screen turn off I would like to run an active screen saver.
If the capability isn't there yet then hopefully the Duo team can build it into V2.
Surface | Surface Duo | Display and screen
    2020-11-11T00:39:44+00:00
    Thank you for your feedback with this.  You may try 3rd party screen saver apps within the Google Play Store.
