I would like to use a Surface Pro 3 pen with another tablet.
2014-06-26T02:23:55+00:00
Hi everyone!
I'm going to try out the Surface Pro 3 soon, but I think that N-trig pen is cool, especially the click the top to open One Note feature I saw when it was introduced.
I've done a bit of research and found out the reason the Surface Pro 3 switched from Wacom to N-trig technology was to make the device thinner as the Bluetooth technology used by the pen eliminated the need for a special digitizing layer on the screen. This led me to believe that the pen would be compatible with any Bluetooth supported Windows tablet. Can anyone confirm this is true and whether purchasing the new Surface Pen is worth my money?
I'm asking this because I'm a little annoyed with the performance of the Wacom digitizer on my own tablet (which is not a Surface) and was thinking that a Bluetooth operated pen, which does not require this special internal hardware to be fitted into the device, would make an appropriate replacement and/or backup in case the Wacom fails to work at all. Better still, I'd love to see the click to open One Note feature functional on my unit as well. What do you say?
Appreciate your advice, as always!
CSD Surface Tester.
Surface | Accessories | Surface Pen
2014-06-26T05:38:09+00:00
That is the reason why to check the specs on the pen.  The particular pen for the Surface Pro 3 only.  The pen itself functions in a dual mode capability but still needs power to do it.  It is classed as a "mechanical" pen because it has electronic components.
The two button batteries pre-installed in the top of the pen functions the Bluetooth connection.  The main battery actually communicates with the pen's driver installed in the tablet to work with the touchscreen.  No digitizer is needed.
If it was a generic pen, you would have an installation disk to install a driver for the pen and that drivers mates with the touchscreen along with adding it as a Bluetooth 4.0 device.
Now, if the Bluetooth connection fails, the pen will still function similar to a stylus where the driver will use the touchscreen like a digitizer surface.  The Bluetooth connection is for software control mainly.
It is a little complex but is a great concept in my thought.  You eliminate hardware (digitizer) and emulate that hardware with software (driver).  Believe it or not, a network adapter and a dial-up modem have been working in that fashion for years; where the driver was actually the modem (simulated hardware) and the hardware (interface card) was just a circuit and connection point.
Right now, you can get Bluetooth and WiFi adapters just slightly bigger than a USB plug.  There is only a very small chip in those and rely on the driver to do the rest.
This pen operates in the same fashion.  Since the driver for it is built in, it cannot be used with any other tablet and this particular model was designed solely for the Surface Pro 3.
Now, like I said, you can get a generic pen (probably from N-Trig) from their web site.  That one will include an installation disk and will work with any tablet that has a touchscreen and Bluetooth 4.0 adapter.  You can't with this particular model.
44 additional answers
    2016-03-30T20:27:55+00:00
    Is the palm rejection a function of the bluetooth or the driver?  What I'm getting at here is this, if I mainly want the palm rejection from the surface pen (even though my device is not a surface but has a bluetooth 4.0) could I use the pen on another touch screen?  So will the palm rejection work on another windows touch screen?  I've tried to understand this from extended searches, and that may be a dumb question but I still thought I'd ask.  I have a feeling that the bluetooth only controls the onenote feature of the pen, not the palm rejection.  Any help would be appreciated.
    2016-03-30T22:50:50+00:00
    The pen is only designed for the Surface Pro 3/4 tablets.  The digitizer is built within the pen itself and communicates with the touchscreen controller on the tablet.
    Palm rejection is part of the touchscreen/digitizer controller and the controller is in the tablet.  A bit confusing, maybe but is how it is designed.
    Palm rejection is where the touchscreen controller detects the pen touching the surface first and then sees multiple contacts elsewhere on the screen and is "supposed" to ignore the other contacts.  That does not work perfect.  Apple added the same thing with their iPad Pro and has proven not to be perfect either.
    So, to keep it basic, the pen you have is only for that tablet series.  The Pro 4 pen will also work with the Pro 3 (I have one with my Pro 3) along with the tip kit.
    The Bluetooth is as you have noted, connects to the tablet to launch functions such as OneNote and performing screenshots.  That is why you have two sets of batteries in the pen since the Bluetooth connection is minimal, those button batteries in the top of the pen should last a year or more.  The main battery in the pen (lower section) can run out in a month or more depending on how much you use it.  It drives the digitizer within the pen and communicates with the touchscreen controller which is both the controller for the touchscreen and the pen.
    In the Pro 1 and Pro 2 machines, those had the digitizer built within the tablet itself.  Thus, the pen for it would not work with a Pro 3/4 model.
    You can use the cheap stylus for touchscreens that are used mainly with iPads on any computer or tablet that has a touchscreen.  Those do not have any function other than to simulate your fingertip.
    In summary, the pen you have is for the tablet you have.  No others except the Pro 4 (and it comes with its own).
    2016-03-31T02:53:30+00:00
    This attachment for the SP3 pen works great... https://m.youtube.com/watch?feature=youtu.be&v=xeldXUmQJys
    2016-03-31T03:21:02+00:00
    Looks like a great option to have and not having to carry around another stylus.
