I would like to use a Surface Pro 3 pen with another tablet.
2014-06-26T02:23:55+00:00
Hi everyone!
I'm going to try out the Surface Pro 3 soon, but I think that N-trig pen is cool, especially the click the top to open One Note feature I saw when it was introduced.
I've done a bit of research and found out the reason the Surface Pro 3 switched from Wacom to N-trig technology was to make the device thinner as the Bluetooth technology used by the pen eliminated the need for a special digitizing layer on the screen. This led me to believe that the pen would be compatible with any Bluetooth supported Windows tablet. Can anyone confirm this is true and whether purchasing the new Surface Pen is worth my money?
I'm asking this because I'm a little annoyed with the performance of the Wacom digitizer on my own tablet (which is not a Surface) and was thinking that a Bluetooth operated pen, which does not require this special internal hardware to be fitted into the device, would make an appropriate replacement and/or backup in case the Wacom fails to work at all. Better still, I'd love to see the click to open One Note feature functional on my unit as well. What do you say?
Appreciate your advice, as always!
CSD Surface Tester.
Surface | Accessories | Surface Pen
2014-06-26T05:38:09+00:00
That is the reason why to check the specs on the pen.  The particular pen for the Surface Pro 3 only.  The pen itself functions in a dual mode capability but still needs power to do it.  It is classed as a "mechanical" pen because it has electronic components.
The two button batteries pre-installed in the top of the pen functions the Bluetooth connection.  The main battery actually communicates with the pen's driver installed in the tablet to work with the touchscreen.  No digitizer is needed.
If it was a generic pen, you would have an installation disk to install a driver for the pen and that drivers mates with the touchscreen along with adding it as a Bluetooth 4.0 device.
Now, if the Bluetooth connection fails, the pen will still function similar to a stylus where the driver will use the touchscreen like a digitizer surface.  The Bluetooth connection is for software control mainly.
It is a little complex but is a great concept in my thought.  You eliminate hardware (digitizer) and emulate that hardware with software (driver).  Believe it or not, a network adapter and a dial-up modem have been working in that fashion for years; where the driver was actually the modem (simulated hardware) and the hardware (interface card) was just a circuit and connection point.
Right now, you can get Bluetooth and WiFi adapters just slightly bigger than a USB plug.  There is only a very small chip in those and rely on the driver to do the rest.
This pen operates in the same fashion.  Since the driver for it is built in, it cannot be used with any other tablet and this particular model was designed solely for the Surface Pro 3.
Now, like I said, you can get a generic pen (probably from N-Trig) from their web site.  That one will include an installation disk and will work with any tablet that has a touchscreen and Bluetooth 4.0 adapter.  You can't with this particular model.
44 additional answers
    2014-06-28T04:52:48+00:00
    Yea, try it out at Best Buy to see if it will do the job you want.  I think it will but you can probably do what I am planning on doing and that is wait for the i3 model to ship out on or after 1 August.  It goes for $799 and the tablet has the same components (including pen) as the i5 and forthcoming i7.
    The tablets have potential and run a normal operating system compared to the iPad and Android.
    Now, if you do have or plan to get an iPad, JOT ADONIT does have a pen that is quite like the N-Trig pen and it functions with an app you download (no hardware controller needed).  If you want to check it out, go to http://www.adonit.net/.  When you read the specs on it, it is almost exactly like the N-Trig model.
    So, I think these pens are probably going to be the rage in the near future no matter what computer a person would have.
    2014-07-30T15:14:14+00:00
    N-trig pens work with all n-trig devices.
    I am using the Surface Pro 3 Pen  with my Sony Vaio Duo 13 right now.
    I've had to install some drivers for the Surface pro, but the results are quite satisfactory
    2015-06-10T05:30:37+00:00
    Have a look at http://www.onestylus.com.
    2015-06-10T05:35:30+00:00
    I had figured that there was a potential of them doing so.  At the time of this thread, these where new and not really tested on compatibilities there where available.  I did see that Sony is another customer of N-Trig and am not sure but Samsung maybe as well.
    At least, there will be some models out there where a single pen will work on multi-devices.
