Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2021-01-22T17:46:19+00:00
    Right clicking doesn't give a box that says anything about power.  Only "Update Driver", "Disable Driver", "Uninstall Device", "Scan for Hardware Changes" and "Properties".  Now what??
    2021-01-28T01:39:02+00:00
    You can look in Devices and Printers in Control Panel to see if the Air Pods are there and if they have a power management option.
    nope, the power management option isn't there, I checked. How do I fix this?
    I have to guess as I don't have Airpods. If you found the Airpods in devices and printers double click on it. If you see a hardware tab click on that. You should see a list of device functions. If you see a Bluetooth Low Energy GATT complaint HID device there double click on it. That should open a new window. At the bottom of the window will be a change settings button, click on that to open another window. That window should have a power management tab,
    The Bluetooth Low Energy GATT isnt listed in the device functions on mine either. So its either really hard to find or microsoft doesnt know what their doing (wow shocker). The weird thing is that mine used to work but for some reason it now just perpetually switches from connected to paired every few seconds.
    2021-01-28T21:48:59+00:00
    It really did help; it wasn't at all complicated, rather detailed and very clear
    Thank you very much so
