Airpods Not connecting property to Surface Pro 10
2019-08-30T19:42:05+00:00
I can pair my airpods with my Surface book 2 laptop, however they will rapidly connect and disconnect. And when it says "connected", no sound will play through the airpods. I've tried looking up a couple of fixes online but nothing is working.
Surface | Surface Book | Sound and camera
2019-11-13T20:44:42+00:00
I had the same exact problem with the Airpods Pro. My problem, as you mentioned, was the the rapid flickering back and forth between Paired andConnectedwith the Airpods ultimately never connecting.
For me, the solution was to restart the whole process as follows:
  1. Place your Airpods or Airpods Pro back into the case > Close the case > Set the Airpods down.
  2. On your Surface computer > Settings > Devices
  3. Select Add Bluetooth or other device > Bluetooth
  4. Pickup Airpods Case > Open Airpods case (Don't remove Airpods) > Press/Hold button on back of Airpods case until the Airpods are located by your Surface computer.
Your Surface computer should be able to at least find your Airpods by following the above steps.
*This is where I started having the problem stated at the beginning*
Solution:
  1. Go to settings > Type "Device Manager" in the search box.
  2. Once Device Manager is open, select Human Interface Devices
  3. Locate Bluetooth Low Energy GATT complaint HID device > Right-Click >Properties
  4. Select the 5th tab called Power Management
  5. Locate the checkbox "Allow the computer to turn off this device to save power" and UNCHECK this box!
  6. RESTART COMPUTER! *(This is what ultimately fixed my problem)*
Hope this helps! Wish it wasn't this complicated but oh well ¯\_(ツ)_/¯
2019-12-11T22:53:18+00:00
I couldn't even find a "Bluetooth Low Energy GATT complaint HID device"  under Human Interface Devices, and any other Bluetooth options in the Device Manager didn't have a power management option. However, when I clicked on "Converted Portable Device Control device properties" under Human Interface Devices, I found the power management option and disabled it. My AirPods are working correctly now. I hope I'm not saying this too soon and that it's not just because I just updated my Surface, but I've had this problem for a long time and updates haven't fixed the problem before. Hopefully this will work for you. It's unfortunate we have to deep dive into our settings to get headphones to connect right.
184 additional answers
    2020-06-23T14:15:55+00:00
    Apple is not the problem here. Both my airpods and airpods pro worked from the get go on my Toshiba and my Asus laptop. I got rid of my Surface for being such a mediocre and expensive product. I suggest you do the same before more problems pile up and it embarrasses you at work or gets you fire for not being able to be reliable during work hours like it almost did to me.
    I have never ever had this amount of issues with any other computer.
    This reflects badly on the type of company and people surface are.
    I hope they either make a better product or close down and not offer clients their garbage. If they are laughing at us for buying their “pretty” useless product. Shame on them and shame on you for defending such terrible people.
    2020-06-23T14:26:44+00:00
    Didn't mean for it to come across as I was having a bias on either company.
    I agree that microsoft is the one to blame for this issue, not so much apple.
    But I think you're wrong about the Surface Laptops.
    Surface Laptops are in my opinion -and many others- the best laptop in the market.
    I would choose these laptops over any others due to it's fantastic design and quality.
    2020-06-23T14:29:25+00:00
    Also Paul I've noticed that you've also been replying to other comments encouraging them to get rid of their surface.
    You sound pretty immature and heavily biased against surface products.
