Barb,
Thanks for the follow-up. Here are the results from the netsh wlan sho d command.
Interface name: Wi-Fi
Driver : Marvell AVASTAR 350N Wireless Network Controller
Vendor : Marvell Semiconductor, Inc.
Provider : Marvell Semiconductor, Inc.
Date : 2014-05-23
Version : 14.69.24054.176
INF file : oem5.inf
Type : Native Wi-Fi Driver
Radio types supported : 802.11g 802.11b 802.11a 802.11n
FIPS 140-2 mode supported : Yes
802.11w Management Frame Protection supported : Yes
Hosted network supported : Yes
Authentication and cipher supported in infrastructure mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA-Enterprise TKIP
WPA-Enterprise CCMP
WPA-Personal TKIP
WPA-Personal CCMP
WPA2-Enterprise TKIP
WPA2-Enterprise CCMP
WPA2-Personal TKIP
WPA2-Personal CCMP
Vendor defined TKIP
Vendor defined CCMP
Vendor defined Vendor defined
WPA2-Enterprise Vendor defined
Authentication and cipher supported in ad-hoc mode:
Open None
Open WEP-40bit
Open WEP-104bit
Open WEP
WPA2-Personal CCMP
Wireless Display Supported: Yes (Graphics Driver: Yes, Wi-Fi Driver: Yes)
That last line above confirms the findings of dxdiag that I had run previously.
We are sensitive about our personal data and, as a result, we do not use OneDrive or any other cloud-based storage or sharing apps. So, before I post the
netsh wlan show all command results, which include the names of our network and those of my neighbours, along with other identifiable info such as MAC addresses, channel usage,
et al(?), I hope you will allow me to start by sharing with you just some possibly-pertinent differences in the results from the Surface Pro 2 (that fails to connect) and the HP laptop (that connects fast and flawlessly).
I have highlighted in bold
the items that I am guessing may be pertinent. Of course, as you are the expert and would know far better than I, please let me know which other sections items you would like to see.
======================= SHOW INTERFACE CAPABILITIES ===================
Wireless System Capabilities
[[ no differences ]]
Wireless Device Capabilities
WDI Version (Windows) : 0.0.0.0 [[ HP 0.1.1.5 ]]
WDI Version (IHV) : 0.0.0.0 [[ HP 0.1.1.5 ]]
Firmware Version :
Station : Supported
Soft AP : Supported
Network monitor mode : Supported
Wi-Fi Direct Device : Supported
Wi-Fi Direct GO : Supported
Wi-Fi Direct Client : Supported
Protected Management Frames : Supported
DOT11k neighbor report : Unknown
ANQP Service Information Discovery : Not Supported [[ HP Supported ]]
Action Frame : Not Supported [[ HP Supported ]]
Diversity Antenna : Unknown
IBSS : Supported
Promiscuous Mode : Supported
P2P Device Discovery : Not Supported [[ HP Supported ]]
P2P Service Name Discovery : Not Supported**[[ HP Supported ]]**
P2P Service Info Discovery : Not Supported [[ HP same ]]
P2P Background Discovery : Not Supported [[ HP Supported ]]
P2P GO on 5 GHz : Unknown [[ HP Supported ]]
ASP 2.0 Service Name Discovery : Not Supported [[ HP Supported ]]
ASP 2.0 Service Information Discovery : Not Supported [[ HP same ]]
IP Docking Capable : Not Supported
FIPS : Supported
Instant Connect : Not Supported [[ HP Supported ]]
Dx Standby NLO : Not Supported
Extended Channel Switch Announcement : Unknown
Function Level Reset : Not Supported
Platform Level Reset : Not Supported
Bus Level Reset : Not Supported
MAC Randomization : Not Supported
Fast Transition : Not Supported
MU-MIMO : Unknown
Miracast Sink : Unknown [[ HP Supported ]]
BSS Transition (802.11v) : Unknown
IHV Extensibility Module Configured : Not Supported
Number of Tx Spatial Streams : 0
Number of Rx Spatial Streams : 0
Number of Concurrent Channels Supported : 2
P2P GO ports count : 1
P2P Clients Port Count : 1
P2P Max Mobile AP Clients : 4
Max ANQP Service Advertisements Supported : 0
Co-existence Support : Unknown
Thanks again Barb. I really appreciate your attention to detail.
