Disable double tap zoom feature in Edge
2015-12-06T12:43:09+00:00
How to disable the double tap zoom feature in Edge?
I'm somehow triggering this thing constantly and it's absolutely driving me nuts
Thanks, Pim
Surface | Surface Earbuds | Setup and pairing | Android
    2016-10-15T08:24:39+00:00
    I've had the same trouble when my son tried to play a game on the BBC website using the touch screen on my Surface 3.
    http://play.bbc.co.uk/play/pen/gnkrwjbvsj?exitGameUrl=http%3A%2F%2Fwww.bbc.co.uk%2Fcbeebies%2Fgames%2Fpeter-rabbit-hop-to-it
    2015-12-29T19:19:59+00:00
    Although I'm not the OP, I have the same problem and would like to see a fix for it.
    1. Surface Pro 3
    2. Yes, double tapping on the touch screen
    For example, as it is, it is not possible to open a folder via touch in google drive - requiring me to keep chrome around.
    2015-12-06T17:28:34+00:00
    Hello Pim,
    Thank you for posting your query in Microsoft Community.
    Sorry for the inconvenience caused.
    To better understand the issue
    1.Please let us know the make and model of your PC?
    2.Are you referring to double tapping option in Touch screen ?
    Please get back to us with the necessary information and we will be happy to help you further.
