Surface Laptop 3 Faint Buzzing Sound
2019-10-23T21:50:20+00:00
I’ve got the i5 8GB Surface Laptop 3 (13.5-inch), and today, while browsing the internet, I noticed a fairly faint  buzzing sound coming from under the keyboard. It was faint enough you couldn’t hear it from a couple metres away, and sometimes buzzed continuously, other times buzzed in short repetitive bursts.
It didn’t sound like the fan to me, so I opened up the task manager to see if browsing was straining the computer in some way.
I have updated the computer completely, but the buzzing persisted.
Is this a normal electronics problem? Is it actually just the fan? Or is it possibly a defective unit?
Edit/Update:
I took the device into the MS Store today to see if there was something wrong. The staff took it into the back and tested it. They found increasing the computer's workload caused the sound to increase and described it as a popping static-y sound. They replaced the device and I have a new one now. Unfortunately, I've found through usage that this one is also making the sound. I am waiting to see if a firmware update reduces the noise since it seems pervasive across the devices.
Surface | Surface Laptop | Install and update
    2021-03-17T21:26:24+00:00
    What is this ringcentral app? I’m assuming these comments are spam?
    No, thats no spam! Ringcentral app is just a video conference tool which prevents the CPU from going into IDLE. As long as Microsoft can't solve this problem and I'm disturbed by the coil whine, I'm happy about any app that can stop this noise. The registry entry method unfortunately drains my battery too much.
    2021-03-17T23:39:29+00:00
    Yeah, I looked into it and it's just a video conference and messaging tool. Has nothing to do with the issue we're discussing...
    2021-03-18T16:17:52+00:00
    It does, as if you start the app, it kills this insane noise.
    2021-03-18T16:19:34+00:00
    Nope, I just needed to use this app because of one of my clients, and suprisingly, it killed the coil whine noise.
    2021-03-18T16:29:03+00:00
    Hey! This is a new solution for me as well, so I don't really have any specific info on the battery side. But so far so good!
    The best part is that there's no need to sign-in, it is enough to install the app, allow it to run upon Windows start, and that's it.
    Once you start the device, login page comes up, you click "x", and you're good to go.
    It hepls me, maybe it can help others, too, but I certainly don't have any connection with ringcentral :)
