Surface Laptop 3 Faint Buzzing Sound
2019-10-23T21:50:20+00:00
I’ve got the i5 8GB Surface Laptop 3 (13.5-inch), and today, while browsing the internet, I noticed a fairly faint  buzzing sound coming from under the keyboard. It was faint enough you couldn’t hear it from a couple metres away, and sometimes buzzed continuously, other times buzzed in short repetitive bursts.
It didn’t sound like the fan to me, so I opened up the task manager to see if browsing was straining the computer in some way.
I have updated the computer completely, but the buzzing persisted.
Is this a normal electronics problem? Is it actually just the fan? Or is it possibly a defective unit?
Edit/Update:
I took the device into the MS Store today to see if there was something wrong. The staff took it into the back and tested it. They found increasing the computer's workload caused the sound to increase and described it as a popping static-y sound. They replaced the device and I have a new one now. Unfortunately, I've found through usage that this one is also making the sound. I am waiting to see if a firmware update reduces the noise since it seems pervasive across the devices.
Surface | Surface Laptop | Install and update
    2020-12-31T15:51:54+00:00
    I exchanged my laptop 2 times already and it never worked. I got both times a laptop with the buzzling sound despite I ask that they make sure that the device work. The second time I even get the laptop and when I opened it, it was already on. This is unacceptable. Clearly, MS knows about this problem and does not do anything about it. I guess it is better to loose all these clients than just accept the mistake. But I guess, the word of mouth will take care of make sure that many people does not buy more Microsoft products.
    I lost more than two week of classes due to this replacements and nobody did anything about it and without mentioning all the time that I lost with the paperwork, phone calls and shipments.
    Also, it is unbelieveble that the replacements are refurbrished. Not only they do not fix the problem but they sent me refurrbished devices with the same problem. Therefore I lost my new device !
    Never gonna buy a microsoft product again and sure I am going to tell everybody that I know the same thing !
    2020-12-31T16:04:47+00:00
    The replacements are refurbished devices?!?! Thats completely dreadful?
    My next laptop is certainly not a surface...maybe an XPS 15 or similar.
    2021-01-03T17:56:02+00:00
    Same Issue here with my SL3, constant buzzing noise, really annoying, regretting already not to bought an MacBook!
    I mean these kind off issues are known & predictable in the development process! That is really a shame and absolut unaccaptable!
    2021-01-03T18:24:39+00:00
    Hey everyone, I have the same issue, but only if my battery is at 72 percent or lower or when charging and the battery is full.... Thought this was interesting, I guess it is an battery related issue as sb mention above. Nexus dock does not work for me either. Interestingly, when I open the timeline, the start menu, a program or when scrolling really fast, the sound stops for a few seconds. So maybe it has sth to do with the cpu power draw.
    2021-01-03T19:33:37+00:00
    while chaging the pitch of the realtek speaker, it stops buzzing....
