Surface Laptop 3 Faint Buzzing Sound
2019-10-23T21:50:20+00:00
I’ve got the i5 8GB Surface Laptop 3 (13.5-inch), and today, while browsing the internet, I noticed a fairly faint  buzzing sound coming from under the keyboard. It was faint enough you couldn’t hear it from a couple metres away, and sometimes buzzed continuously, other times buzzed in short repetitive bursts.
It didn’t sound like the fan to me, so I opened up the task manager to see if browsing was straining the computer in some way.
I have updated the computer completely, but the buzzing persisted.
Is this a normal electronics problem? Is it actually just the fan? Or is it possibly a defective unit?
Edit/Update:
I took the device into the MS Store today to see if there was something wrong. The staff took it into the back and tested it. They found increasing the computer's workload caused the sound to increase and described it as a popping static-y sound. They replaced the device and I have a new one now. Unfortunately, I've found through usage that this one is also making the sound. I am waiting to see if a firmware update reduces the noise since it seems pervasive across the devices.
Surface | Surface Laptop | Install and update
    2020-01-14T02:44:36+00:00
    Did anyone get hot while charging ?
    2020-01-14T04:45:53+00:00
    Super Hot - dont worry 'Man Huynh' you are not the only one
    Check my other post - we are also having a debate there specific to heating problem and fan noise for no damn reason when ever we charge and sometime randomly gets hot. Microsoft says its common if it gets 'slightly warm'
    "I SAID HOT --- not slightly warm" - there is a difference Microsoft - but we need more people complaining i guess for them to pay attention - JOIN the fight brothers !!!!!
    2020-01-14T07:50:21+00:00
    Yeah! I think this issue can fix with a firmware update. The SL3 just get hot when using and charging it at the same time. When Turn off it and charging, it's very cold.
    2020-01-14T08:45:51+00:00
    I'm praying its not hardware fault. I'm not very confident at this stage a firmware update will fix it. But lets wait and see. It's a good laptop, I already exchanged for the second one but same issue. I hate to return it for a mac or dell.
    2020-01-14T10:44:18+00:00
    Yes, I had the platinum alcantara base model with this issuse.
