Touch screen unresponsive when 'double tap to swap screen'
2021-04-11T10:25:58+00:00
Hello.  I love duo so much but this is so annoying And I tried everything like factory reset but cannot resolved.
using duo with smartphone mode, I'm usually using right screen, and when left screen say 'double tap to swap screen', suddenly Half of right screen(left side) is unresponsive.
It means Cannot type Q, W, A, S, Z, D until that 'double tap to..' Dissapear. Almost 5 seconds.
It is opposite with left screen. Cannot use Half of screen (but right side this time) so I cannot type P, L, M, O, K.
But certainly, It is not matter of screen size I think Because
I changed size and moved swift keyboard to End of right side
But stil cannot type Q, W, A, S, Z. D.
.. Seriously, What is wrong with duo?
I don't know why but after recent patch duo always saying double tap to swap screen even I do not want to swap screen so almost of time I cannot use half of screen when I using smart phone mode now. It is extremely fraustraing so I really hope fix this. Is anyone there solved this problem?
Surface | Surface Duo | Display and screen
    2021-04-29T01:51:29+00:00
    thanks for reply.
    yes! now it is way, way better than before
    after system update.
    but actually, very sometimes it happens still,
    I don't know why, so I still make keyboard so small and move to end of side.
    I hope next update can fix this.. and then I can use Split keyboard of swiftkey.
    2021-04-28T19:39:04+00:00
    Is this issue still happening, if so have you installed the latest system update by going to Settings, System, System Update and Check for updates?
