7 days to die
2016-07-08T15:33:24+00:00
will my surface pro 3 run this game ?
Surface | Surface Duo | Install and update
    2016-07-31T00:21:21+00:00
    Hi Carl225.
    Welcome to Microsoft Community and thanks for posting your concern.
    Surface Pro 3 is a full laptop replacement and can run many of the most popular PC games. The ability of the device to run the game that you want will depend on the game's minimum and recommended system requirements. You can check the Technical Specifications of Surface Pro 3 to see if it's compatible with the program.
    Regards,
