why surface duo shuts off randomly after installing updates?
2023-04-25T03:52:01+00:00
Surface duo 1 shuts off randomly indicating low battery even after being disconnected from charging. I connect the phone to charge and it wont turn on. when it does turn on, it stays on for like 10 mins and then shuts off again, fully charged
Surface | Surface Duo | Power and battery
    2023-04-27T18:55:18+00:00
    Hello MarcelaRojas Rembao,
    It sounds like there may be an issue with your battery that would require a replacement.
    Here’s how to request a repair or replacement for your device.
    Note: Your device must be registered under your Microsoft account to submit a repair request.
    1.  Go to Device Services and sign in with your Microsoft account.
    2.  Select the device you want to submit a service request on.
    3.  Click 'Info & Support
    4.  Select Start Order and follow the instructions to complete the submission process.
