Help :( My surface pro 4 has horizontal lines across the screen!
2017-01-14T10:53:30+00:00
Hello. I'm having a problem with my Surface pro 4 lately.
my surface display screen has a horizontal line across the top of the screen when I use my Surface for a while (around 10-20 minutes without light usage like web browsing but 1-5 minutes for heavy usage like rendering or gaming) also the lines will keep appears more and more the longer I use it.
as you can see at the first and second picture, you can see multiple line across the top of my screen already. and when the screen has around 6-7 lines then the screen came to this.
![](https://learn-attachment.microsoft.com/api/attachments/35c1c9e4-e66b-40e9-bc4a-c3bf72fdfc3b?platform=QnA)The whole screen has lines all over it and is has some desync display like this all the time. :(
seems like the more heat it has the more of this symptom appears. the only way I can fix it that I know right now is 1) turn of the device for a while then turn it on again 2) put it in a cool place like a fridge for a minute to cool down.
does anyone has this kind of problem like I have right now? also does anyone knows what causes it? and how to fix it?
Ive been into this problem for many months now and this surface pro 4 is my 4th (refurbish) replacement already. I wasted 7-20 days on waiting for each replacement and it ruined lots of my work schedule and my income which is terrible! Id love to sell it away just to buy other brand instead of struggling with this :(
and sorry for my English which isn't so good but I hope anyone will be able to give me an opinion or answer soon
thank you.
2017-09-11T01:02:12+00:00
Solution: External cooling.
I was having the same issue, but today found the source. It seems the issue is either the internal cooling system is underperforming or the on-board graphics controller has gained increased sensitivity to heat.
For the first year of using my SP4, I had no such issue. I constantly monitor internal temperature and have never run hotter than mid-60s. Recently however after using my device for an extended period unplugged or a shorter amount of time while plugged in, the lines and screen desync occur.
I tested the heat damage idea by using my SP4 while plugged in for half of the day today. I watched videos, used the pen, and had multiple programs running with no screen issues. The key here is that I set up a desk fan to blow cold air onto the SP4.
So to prevent the lines and display desync, you need some kind of fan or external cooling for your SP4. I'd say start with a small/cheap USB fan, and if that isn't powerful enough move to something bigger. Be sure the fan is aimed at the top left corner of the back because that's where most of the heat localizes.
56 additional answers
    2017-12-29T04:42:13+00:00
    Best thing you can do is buy a new comp, unfortunately.
    Even if it was covered by warranty, its been noted that microsoft refuses to allow the problem to be covered, because apparently failing hardware isn't their fault, even though its obviously a defective product.
    I bought a Samsung Ativ book 9, so now not only is my graphics card a safe distance away from everything else that can fry it out, but I can also put the thing on my lap without fear of it falling over. Yay.
    Note that my issue was not solved, however, I will be unsubscribing from the forum, now that my (in total) 14-1500 dollar investment is sitting at the bottom of the drawer. So technically, I fixed the issue myself.
    2018-02-22T05:43:55+00:00
    I have a similar problem.  I also have a Surface Pro 4 and get the same horizontal lines on the top of my screen in the same heating/charging situations. Exactly the same.
    But mine does something different.
    After a few minutes my screen develops a trace. Previous screens over lap each other. Almost like I'm in photoshop with multiple layers and have the opacity turned down to 50% for all layers. Example: If I'm using the internet and switch tabs I can see both tabs at once overlapping each other. If I close the program, I see a trace of both tabs and my home screen at once. Apparently this happens to others because I've seen other questions online saying similar things. If I let my computer cool or sleep this seems to solve the problem but now it happens every time I use my computer and its making it impossible to get any work done. I've had my SP4 for about 6 months. Also, mine doesn't have horizontal lines going from top to bottom of my screen, only the first initial lines at the top appear before it goes into its trace like state.
    I caught this on video and I'm going into a Microsoft store this weekend. Hopefully I will have an answer. But something tells me I'll need to get the computer replaced.
    I have not attempted any changes to updates or uninstalling things. However this has been going on for over a month and there have been multiple updates since that time.
    I've had CPU over activity problems before and the people in store helped me. Although they seemed confused on the phone maybe we will stumble across a solution. I will let you know if anything works.
    2018-04-04T20:12:26+00:00
    I have this issue too, I tried all fix methods but it didn't work. Factory Reset >> Uninstall and reinstall didn't work >> safe mode uninstall graphic card reinstall. I want to know why the surface expensive and have this issue :( so irritating. They all lying about fixing the problem. DAAAAAM!
    2018-05-23T11:05:26+00:00
    MIcrosoft are now giving replacements even if out of warranty for Surface Pro 4 with screen problems as long as the Tablet is less than 3 years old
    Here is the link
    https://support.microsoft.com/en-us/help/4230448/surface-pro-4-screen-flicker
    Spread the word!
