Help :( My surface pro 4 has horizontal lines across the screen!
2017-01-14T10:53:30+00:00
Hello. I'm having a problem with my Surface pro 4 lately.
my surface display screen has a horizontal line across the top of the screen when I use my Surface for a while (around 10-20 minutes without light usage like web browsing but 1-5 minutes for heavy usage like rendering or gaming) also the lines will keep appears more and more the longer I use it.
as you can see at the first and second picture, you can see multiple line across the top of my screen already. and when the screen has around 6-7 lines then the screen came to this.
![](https://learn-attachment.microsoft.com/api/attachments/35c1c9e4-e66b-40e9-bc4a-c3bf72fdfc3b?platform=QnA)The whole screen has lines all over it and is has some desync display like this all the time. :(
seems like the more heat it has the more of this symptom appears. the only way I can fix it that I know right now is 1) turn of the device for a while then turn it on again 2) put it in a cool place like a fridge for a minute to cool down.
does anyone has this kind of problem like I have right now? also does anyone knows what causes it? and how to fix it?
Ive been into this problem for many months now and this surface pro 4 is my 4th (refurbish) replacement already. I wasted 7-20 days on waiting for each replacement and it ruined lots of my work schedule and my income which is terrible! Id love to sell it away just to buy other brand instead of struggling with this :(
and sorry for my English which isn't so good but I hope anyone will be able to give me an opinion or answer soon
thank you.
2017-09-11T01:02:12+00:00
Solution: External cooling.
I was having the same issue, but today found the source. It seems the issue is either the internal cooling system is underperforming or the on-board graphics controller has gained increased sensitivity to heat.
For the first year of using my SP4, I had no such issue. I constantly monitor internal temperature and have never run hotter than mid-60s. Recently however after using my device for an extended period unplugged or a shorter amount of time while plugged in, the lines and screen desync occur.
I tested the heat damage idea by using my SP4 while plugged in for half of the day today. I watched videos, used the pen, and had multiple programs running with no screen issues. The key here is that I set up a desk fan to blow cold air onto the SP4.
So to prevent the lines and display desync, you need some kind of fan or external cooling for your SP4. I'd say start with a small/cheap USB fan, and if that isn't powerful enough move to something bigger. Be sure the fan is aimed at the top left corner of the back because that's where most of the heat localizes.
56 additional answers
    2017-11-27T18:27:05+00:00
    SInce there is no Microsoft store in the UK I rang microsoft UK support
    He suggeested reloaded the drivers for the display - which I'd done
    We then ran Diagnostic Toolkit.  Still no better
    He then suggested reinstalling WIndows 10.   He sent me a link to make a USB restore disc but not instructions on how to use it so as to reinstall Windows without losing all my files.
    Can I reinstall WIndows without wiping my files?
    TD
    2017-11-27T18:29:44+00:00
    You have to wipe your files if you reinstall windows 10.
    Don't even bother, its not going to do any different. Not even deleting all of your files and hassling yourself even more is going to save it.
    2017-11-27T18:42:32+00:00
    So what do I do?
    The screen problem is so unpredictable.   I am using it now with AC plugged in.   The fan is running hard.  Half and hour ago the screen had double image but for some reason its now ok.   The case temperature is now 40deg C, (102F) which the hottest that I have measured.  The CPU is running at 65% as I am doing an Acronis backup.   In spite of this, the screen is fine - at the moment
    If I plug in an additional USB screen, that works perfectly, but its a pain to carry around!
    Do I throw the Pro away..........?
    TD
    2017-11-27T23:36:19+00:00
    As I said, I'm gonna bring mine to another shop (one that isn't Microsoft, and sells computer parts, so they aren't just about waiting until my warranty conveniently expires and charging me for a new device completely) and see if they can replace it/give me a discounted one since its obviously defective/see what they can just do. If not, I'm gonna get something cheaper and of better quality for school. The sad thing is, I can bring a desk fan and a second monitor in my bag all day, so the surface is quickly becoming a worthless piece of garbage.
    I take it to the store in a little over two weeks, will send update then.
