New Surface Pro 7 shutting down randomly
2020-02-11T05:44:13+00:00
I'm tired of all these issues now. At first, a few days ago, I was working on this laptop and it shut down randomly. I switched it on, but again it shut down randomly. In 20 minutes, this happened thrice. I tried something, and then it worked fine for a day. Then today again, it is happening. The diagnostic kit says there's nothing wrong. Please help.
    2020-10-09T00:48:33+00:00
    I run Windows 10 Pro on my Surface Pro 7 (i7, 256Gb, 16Gb) with no problems. I had random shutdowns when I first purchased the device, but these were resolved entirely with the 2004 Window 10 update. Mostly they occurred while the device was asleep, not while I was working. I usually have the power mode set to "Recommended" or "Better Performance" (not "Best Performance"), though, to reduce fan noise.
    Point being, I don't believe downgrading to Windows 10 Home will resolve this problem. I would say that either there is a problem with your Windows installation, which may be resolved with a refresh/clean install. Or third-party software you're using is causing the system to crash. Or third-party hardware you're using is causing the system to crash. Or your device is faulty and should be replaced by Microsoft.
    2020-10-09T00:54:40+00:00
    Yes, the problem seems to be solved.
    2020-10-09T01:23:00+00:00
    Thanks i have alredy upgrade with W 2004 and norhing. The OS when I purshased was W10 home edition. I will follow your recomendation for a fresh W10 Pro instalation and see what happen. Thank you for your comments and time
    2020-10-19T16:53:33+00:00
    I had that problem too.   After doing many restores and firmware updates, I had to send it in for replacement.
    The 2nd one, would shutdown randomly if I didn't move the mouse constantly.  (if left idle for like 20 seconds it would shutdown).
    I updated firmware and latest updates.  Problem went away. (had to keep moving mouse while getting updated firmware).
    Fine for 5 weeks.
    Then last week, something happened and it started to random shut down again!
    Today, I did this:
    Downloaded all updates (keep moving mouse; restarted)
    Downloaded and installed new firmware was released 10-14-2020. (get the right one for your windows build. search ABOUT PC and look at your build).
    Still didn't fix my PRO 7.
    I found an answer on another forum.
    To anybody that is having random shutdown due to idle, do this:
    Go to Device manager -> system device -> intel management engine interface -> power management tab, uncheck "allow the computer to turn off this device".
    I did this today and my Pro 7 hasn't shutdown yet.
    2020-10-19T20:35:39+00:00
    Thanks I just did that this morning lets see what happen no random shutdowns yet. Though to avoid blue screens i had to stop using the MS surface por 7 Docking Station. I couldnt find the docking station in the device manager to update or rollback drivers
