How do I insert a micro sd card in my Surface duo?
2021-03-30T21:02:06+00:00
I see a (slot) on the lower part of the right panel.
How do I open it without damaging it?
Surface | Surface Duo | Sound and camera
    2021-03-30T21:16:34+00:00
    Hi Scott Sasse,
    Thank you for reaching Microsoft Community.
    Surface Duo does not have a micro SD card slot. The slot you see on the lower part of the right panel is the SIM card slot. See Surface Duo features for details. To insert a SIM card, please see this page for details: Insert a SIM card into your Surface.
