sound keeps muting
2012-10-27T20:47:09+00:00
I was listening to a song on the tablet and then went back to the start page to do something else and all of a sudden I thought my song stopped playing but it hadn't. The sound muted itself.
Then I set up the tablet so I could view my facebook pictures on the tablet. As I was looking at them, I noticed it also showed some videos I uploaded to facebook so I wanted to see what they looked like on the tablet but there was no sound. I thought it was because they were from facebook but I checked the speaker and noticed the sound got muted again.
Why does this happen and is it suppose to happen?
Surface | Other
2013-03-22T15:48:21+00:00
Hello all.
I’d like to update you on this issue regarding random muting of Surface.   After further investigation, it is recommended that you connect your Touch Cover and ensure any and all updates have been installed to Surface.
My apologies for any confusion or troubles this has caused. Please let us know if you have any further questions.
Kindest Regards.
To check for updates:
  1. Open PC Settings, by swiping in from right edge (or, if using a mouse, point to upper-right corner of screen)
  2. Tap or click Settings
  3. Tap or click Change PC settings
  4. Under PC settings, tap or click Windows Update
  5. Tap or click Check for Updates
2012-11-07T22:23:52+00:00
Greetings everyone,
Regarding the issue of having the sound mute randomly, and in TH IT's case, unmute, please get in touch with the Surface Technical Support to exchange the Touch / Type Cover. We're still investigating the issue, however it appears that the cover may be the issue.
You can do the exchange yourself here: http://myservice.surface.com or by contacting our Technical support team here: http://www.microsoft.com/surface/support/contact-us/.
Please let us know if the exchanged Touch Cover / Type Cover resolves the issue for you.
194 additional answers
    2013-01-30T20:04:25+00:00
    Hey guys,
    my surface mutes but i don't have a touch cover! I had thia problem with my first surface too, so the support exchanged it. Now I have my second one but the problem is also represent!
    2013-02-13T08:29:32+00:00
    Does anyone have an update on this bug? I just got the surface pro with the touch cover and its very annoying. Does the type cover not have this problem? Thx
    2013-02-14T20:47:49+00:00
    I notice that neither the Surface firmware update or the driver updates released on patch Tuesday have resolved this issue. Still awaiting a fix...
