sound keeps muting
2012-10-27T20:47:09+00:00
I was listening to a song on the tablet and then went back to the start page to do something else and all of a sudden I thought my song stopped playing but it hadn't. The sound muted itself.
Then I set up the tablet so I could view my facebook pictures on the tablet. As I was looking at them, I noticed it also showed some videos I uploaded to facebook so I wanted to see what they looked like on the tablet but there was no sound. I thought it was because they were from facebook but I checked the speaker and noticed the sound got muted again.
Why does this happen and is it suppose to happen?
Surface | Other
2013-03-22T15:48:21+00:00
Hello all.
I’d like to update you on this issue regarding random muting of Surface.   After further investigation, it is recommended that you connect your Touch Cover and ensure any and all updates have been installed to Surface.
My apologies for any confusion or troubles this has caused. Please let us know if you have any further questions.
Kindest Regards.
To check for updates:
  1. Open PC Settings, by swiping in from right edge (or, if using a mouse, point to upper-right corner of screen)
  2. Tap or click Settings
  3. Tap or click Change PC settings
  4. Under PC settings, tap or click Windows Update
  5. Tap or click Check for Updates
2012-11-07T22:23:52+00:00
Greetings everyone,
Regarding the issue of having the sound mute randomly, and in TH IT's case, unmute, please get in touch with the Surface Technical Support to exchange the Touch / Type Cover. We're still investigating the issue, however it appears that the cover may be the issue.
You can do the exchange yourself here: http://myservice.surface.com or by contacting our Technical support team here: http://www.microsoft.com/surface/support/contact-us/.
Please let us know if the exchanged Touch Cover / Type Cover resolves the issue for you.
194 additional answers
    2012-11-22T23:16:16+00:00
    Greetings everyone,
    This did not solve the issue for me. I got a replacement touch cover due to the seam issue where it comes apart. However I was also getting the random mute issue. After the replacement arrived I'm still getting the mute issue, now I'm either really unlucky or this is not the cause of the problem.
    Help or advice would be nice.
    2012-11-23T03:01:35+00:00
    A point was made a while ago that it may be an error with a particular batch (or batches) of covers.  This being said, it may be prudent to at least check if your replacement cover was from the same batch or line as you old one...?  It may even be a random glitch in the manufacturing process of the covers that fixes the issue for some people.
    Still encountering the issue here.  I can further add that it does appear to more readily happen when I first touch the touch pad after doing something else for a while, so it may indicated an accumulated charge that when discharged resembles the "mute" signal and the Surface reacts accordingly.
    It also just recently occurred when I put my lapdesk with the Surface on it, open and standing with cover attached, onto a pillow with a drop of a few cm.
    Thinking that I might just get the cover exchanged seeing as there doesn't appear to be much progress in here, even though there are posts stating that there have been no improvement.  Maybe I'll get lucky with a latter batch or something that just happens to not have the issue :-/
    2012-11-23T22:23:19+00:00
    I replaced my cover about two weeks ago and I have not had the muting problem since, I'm just throwing this up here maybe it will help someone, but the batch number on my cover is 104481323951/ model #1515 / N1364 Z396
