sound keeps muting
2012-10-27T20:47:09+00:00
I was listening to a song on the tablet and then went back to the start page to do something else and all of a sudden I thought my song stopped playing but it hadn't. The sound muted itself.
Then I set up the tablet so I could view my facebook pictures on the tablet. As I was looking at them, I noticed it also showed some videos I uploaded to facebook so I wanted to see what they looked like on the tablet but there was no sound. I thought it was because they were from facebook but I checked the speaker and noticed the sound got muted again.
Why does this happen and is it suppose to happen?
Surface | Other
2013-03-22T15:48:21+00:00
Hello all.
I’d like to update you on this issue regarding random muting of Surface.   After further investigation, it is recommended that you connect your Touch Cover and ensure any and all updates have been installed to Surface.
My apologies for any confusion or troubles this has caused. Please let us know if you have any further questions.
Kindest Regards.
To check for updates:
  1. Open PC Settings, by swiping in from right edge (or, if using a mouse, point to upper-right corner of screen)
  2. Tap or click Settings
  3. Tap or click Change PC settings
  4. Under PC settings, tap or click Windows Update
  5. Tap or click Check for Updates
2012-11-07T22:23:52+00:00
Greetings everyone,
Regarding the issue of having the sound mute randomly, and in TH IT's case, unmute, please get in touch with the Surface Technical Support to exchange the Touch / Type Cover. We're still investigating the issue, however it appears that the cover may be the issue.
You can do the exchange yourself here: http://myservice.surface.com or by contacting our Technical support team here: http://www.microsoft.com/surface/support/contact-us/.
Please let us know if the exchanged Touch Cover / Type Cover resolves the issue for you.
194 additional answers
    2012-11-05T19:55:44+00:00
    I've got exactly the same problem.  It seems pretty random.
    2012-11-05T21:00:02+00:00
    Hello Dewain,
    If you are still having this issue, please perform the following steps in order to ensure that there is a clean connection between the Surface and your Touch or Type Cover.
    First, connect and disconnect the Touch or Type Cover several times to see if it is just a bad connection.
    Next, moisten a lint-free cloth (LCD or an eyeglass cleaning cloth works great) with a little rubbing alcohol and rub the cloth over the contact points on the Touch or Type Cover.
    You will need to let the Touch or Type Cover sit for a few minutes to allow for the evaporation of the rubbing alcohol.
    Finally, reattach the Touch or Type Cover back to the Surface.
    If this does not resolve the issue, you may want to try and Refresh your Surface.
    Let us know if this helps.
    Rebecca_AA1
    2012-11-05T21:27:37+00:00
    Yes, it doesn't drop to zero but only mutes. On another note, I let it mute the whole day to see if it will auto unmute and it did happen when I was using the trackpad on the touch cover.
