Hello ReginaldW050877,
Can you please enter safe mode on the device and see if the issue is still present in that mode?
| Instructions to enter safe mode:<br><ol><li><p data-prewrap="true">Press and hold the power button until the "Power menu" appears</p></li><li><p data-prewrap="true">Press and hold on the "Restart" and a pop-up should appear to reboot to safe mode.</p></li><li><p data-prewrap="true">Press 'OK' and your device will reboot into safe mode.</p></li><li><p data-prewrap="true">You can verify you are in safe mode by seeing the "Safe mode" watermark in the lower-left of the screen.</p></li><li><p data-prewrap="true">In order to get back into normal boot mode, simply restart the device by either clicking 'Restart' in the power menu or by shutting down and rebooting.</p></li></ol> |
If the same thing happens there, then one of the Cameras may have failed and you device would need to be replaced to regain this function
