Surface Duo screen rotation not working
2021-03-19T17:06:13+00:00
Just picked up a used surface duo and the screen rotation does not work, I've check all settings that I know of, and made sure the auto rotation is on. I've also noticed that when I flip the screen all the way back, the back screen stays on. Any suggestions would be greatly appreciated. I've updated the phone to the latest version.
Surface | Surface Duo | Display and screen
    2021-03-20T16:28:53+00:00
    Hello LorneFoote,
    Thanks for reaching Microsoft Community and posting your concern here.
    In this case, please try to force your Duo to shut down and restart by holding down the power button. Reset the settings back to default and set the screen rotation one more time. If issue persists, Reset Surface Duo to factory settings.
    Let me know how it goes by simply replying on this thread.
    StevenK
    2021-03-20T16:36:54+00:00
    Thanks for the response Stevenk I've tried all these suggestions and still no rotation.
    2021-03-20T16:43:43+00:00
    Hello LorneFoote,
    Thanks for keeping us posted.
    In this case, we suggest to contact Microsoft Surface Support to seek options for your device or possible replacement. If you're located outside United States, see Global Support.
    Regards,
    StevenK
