Surface Studio UEFI SATA setting
2020-04-29T13:20:00+00:00
I want to know how to change the Surface Studio UEFI SATA setting.
I have to change the SATA controller to reinstall Win 10.
Thanks.
Surface | Surface Studio | Install and update
  1. Deleted
    2020-04-30T05:36:27+00:00
    Hi Surface2018,
    Thank you for reaching out to Microsoft Community. Please allow me some time to raise this concern internally. We'll get back to you as soon as we get updates on this concern.
    Thank you.
    Kind Regards,
    Marrion Y.
    2020-05-01T01:08:42+00:00
    Thanks Marrion.
    2020-05-01T05:30:13+00:00
    Hi Surface2018,
    Regarding with this concern, you are trying to re-install Window son the device using a USB Recovery Image, right?
    Were you able to try to proceed in re-installing without changing UEFI SATA settings? What happened? We would like to know since usually, in re-installing Windows, it can just be done without changing UEFI SATA settings.
    What happened before now that caused you to change UEFI SATA settings?
    Hope to hear from you.
    Kind regards,
    Marrion Y.
