Please post in English in this English forum.
Не работает Realtek HD Audio Manager
Впервые за несколько поколений Windows сталкиваюсь с тем, что не работает менеджер Реалтек. В результате нельзя настроить звук для всей системы - эквалайзер, окружение и т.д. Устройство Microsoft Surface Book, сборка Win 10 Pro 1079. Причем на предыдущей сборке хотя бы можно было откатить драйвера до Realtek 2.76, а теперь откат приводит к появлению кастрированного диспетчера без возможности регулировать звук. Вопрос: какого черта микрософты наехали на реалтек? Верните немедленно поддержку диспетчера Реалтек.
Surface | Surface Book | Sound and camera
2018-02-02T10:55:24+00:00 Not working Realtek HD Audio Manager
For the first time in several generations of Windows confronted with the fact that Manager Realtek HD Audio is not working . In result, I cannot set the sound for the entire system - equalizer, environment etc. My device Microsoft Surface Book build of Win 10 Pro 1079. And on a previous build of Win 10 even if it were possible to roll back the Realtek driver to 2.76, and now the rollback leads to a neutered Manager without the ability to adjust the sound. Question: what the hell Microsoft ran for Realtek? Return immediately support for Manager Realtek. HD Audio.
2018-02-04T11:22:46+00:00 Good feedback - died feedback? May I have answer?
2018-02-06T05:46:48+00:00 Hello,
Let's look at this audio device issue. When did the issue start? What changes have you made prior to the issue occurring? Do you have the latest Surface and Windows updates installed? Tell us more we'll be here to help.
2018-02-06T07:33:59+00:00 Problems was started with buying of Surface. I use Realtek HD Audio manager many years&many devices, But on Surface manager not work. I replace drivers to 2.76 and manager worked. But I receive 1079 and manager died totally! Now I have manager without extended settings, without equalizer. How I can use full worked HD Audio manager? I must have this for $1500 which I payed!
