Try running the Diagnostic toolkit to see if that can resolve the sound problem.
I've had a Microsoft Surface Book for about 5 Months and all of a sudden my headphones stopped working; meaning no sound whatsoever through my headphones while plugged in. doesn't matter what headphones i plug in the Audio devices control panel says there't nothing plugged in. my best guess is that its a hardware problem but i don't understand why or know what i can do about it. is there even a troubleshooter for this type of problem?
Also there are a few more troubleshooting steps available
https://support.microsoft.com/en-us/help/402347...
Hope this helps. Let me know
Linnell
this toolkit only tells me that there "might be a problem with my pc"
You may need to get hardware support Your unit should still have it's warranty.
I don't see that you've tried a two button reset -
Step 1: Press and hold the power button on your Surface for 30 seconds and then
release it.
Step 2: Press and hold the volume-up button and the power button at the same
time for at least 15 seconds and then release both.
The screen may flash the Surface logo, but continue holding the buttons
down for at least 15 seconds.
Step 4: Press and release the power button to turn your Surface back on. You
should see the Surface logo.
Also, is anything banged out in device manager for audio devices?
