Trackpad responsiveness issues
2015-10-28T05:03:03+00:00
I'll start off by stating I'm used to a Macbook Pro when it comes to the trackpad, do I may be a little biased. However, when using the trackpad, I'm specifically having a problem when using two finger scrolling. It seems to have about a one second (maybe half second) delay when I start to try and scroll a web-page. Basically, if I start with two fingers at the top of the trackpad and swipe down to scroll, the screen doesn't start scrolling until my fingers are halfway down the trackpad. Sometimes it struggles to recognize that I'm trying to scroll at all, and I have to swipe several times on the screen.
This issue doesn't happen in the settings screen, or when scrolling through the start menu. However, it does happen when in both Edge and Chrome, and also even happens in Windows Explorer, scrolling through a big directory.
I've turned off the pointer delay (and I keep accidentally tapping it), so I know it's not that. Just using it as a pointer doesn't seem to have any delay, and using touch to scroll has no delay at all. I've tried other settings like increasing the lines scrolled to 15, and that doesn't make it smoother or more response, just makes it scroll further and it seems even more jerky.
Anyone else see this? More importantly, any one have ideas on how to fix this? Yes, I've installed all available updates.
Surface | Surface Laptop | Install and update
    2015-10-28T13:04:35+00:00
    I just read your post and would agree that my Surface Book i7/256 trackpad is behaving the same way with default settings.
    2015-10-28T19:07:41+00:00
    Got a new Surface book, encountering several problems...
    One of which is that when waking from sleep, my trackpad will not respond.  Keyboard will continue to work, but no trackpad.  Looked in device manager, and it was nowhere to be found.
    Able to fix it by detaching screen and reattaching or by rebooting (sometimes doesn't work).
    2015-10-28T19:21:49+00:00
    Mine works exceptionally well.  Key settings for me are this:
    Multiple lines at a time:  7 lines
    Short Delay
    Cursor speed 7
    2015-10-29T00:34:40+00:00
    I have very similar settings now. I've tweaked them around a lot, and no matter what I do, in most applications, two finger scrolling needs my fingers to move a good inch before it registers that I'm scrolling. It's making it real hard to use. Everything else about it is fine. Except that they needed a little rougher texture on the glass. My fingers stick to it a lot more than they should.
    Edit: Just tried a game to see how it worked. After exiting, my two finger scrolling wouldn't work at all. Tried rebooting, and got a blue screen. Such fun.
    2015-10-29T19:49:54+00:00
    I also own a Macbook Pro, and even though the SB trackpad is better than previous MS attempts, it is still not as good. The scrolling feels rough, I'm not sure it can be made better at the moment. The surface of the trackpad is also more sticky than the MBP, which is much smoother.
